Hi
I’m using pixhawk orange cube and I recently tuned my aircraft, but my UAV is not performing stable flights. It is shaking on position hold mode and also it’s drifting from it’s position. I’m attaching a log file and also the flight path which it followed.
I guess you Auto Tuned it w/o setting some other parameters first like the Notch Filter, these which are at default:
PSC_ACCZ_I,1
PSC_ACCZ_P,0.5
And read this as they are at default also: Setting Motor Ranges
Position Hold should be deprecated. Use Loiter.
And you should have current logging.
Actually I tuned it and had around 20-25 flights but after that I started facing these issues. The UAV started following zig-zag path and also it was vibrating a lot. In previously executed flights, it was stable and was executing missions without any issue.
I would blame it on hardware fatigue due to vibrations. Make sure all screws are tight and tune it methodically to reduce at least the self induced oscillations. Then it might work a couple of more years without issues.
I did check the hardware before flight and everything was perfectly fitted. There might be some other issue, and it could be some issue with the firmware.
Because I never faced such issues with any of my copter earlier but with this one and another one too, I faced the same issue. And these issues started at the same time, that’s why I was thinking in this direction that there might be some issue with the firmware.
Yes, mechanically each is a copy of other. All the electronic components were same and the firmware was same too, yet I faced this issue with only two copters.
The firmware is a (100% identical) digital copy of each other.
The configuration has calibration values that are chip dependent. The chips are different, so the configuration must be different for the system to work properly.
The hardware is impossible to be 100% identical (laws of physics)
Yes, I’m thinking in this direction only, because every other part was manufactured by the same machine and it was also assembled using the same methods, so how can it starts behaving like this even when no-one has touched neither the hardware nor the software.
No, I didn’t make any changes in the firmware. I used the same quad with same parameters without making changes to anything.
Can it be an issue with the tuned params of the quad?
I don’t think that your last answer to @amilcarlucas is helpful.
Go back to all of his questions and answer these.
It is you who wants to get help.
If nothing changed to the drone, no firmware change, no hardware change, no parameter change and before everything was good tuned and after a while it is start vibrating that probably some mechanical part is not as good as you think
