Hello, I have set up a configuration where all 3 motors tilt to VTOL from the forward flight for my tricopter setup. The motors however are unresponsive in QSTABALIZE, QHOVER, and input from the controller to motor 1, motor 2, and motor 4, but I know the controller works since the throttle of Radio Calibration is responsive and so are the elevons. The 3 tilt servos are responsive to input from changing modes(unlike the throttle). Also, the throttle responds when I add a throttle part instead of motor 1, 2, etc., I don’t know If that helps. Do you have a fix for this issue? Am I supposed to use different motor outputs?
here is the param file
vtolwingparams.param (23.0 KB)
