I have a hex and I’m using the turnigy 9x TX and RX
For some reason, fail safe does not work on my hex. When I turn off the receiver, the values stay the same. I dont know what is wrong. I am using a 2 position and 3 position switch to get 6 flight modes so I dont know if that has anything to do with it. I updated firmware too so that shouldnt be it.
Since fail safe does not work, today I tried using a nito truck fail safe. turnigy mini failsafe from hobbyking.
When it senses a signal loss, it outputs a predetermined value (I set it at 960)
I bench tested and it worked great.
Also, if it senses 4.2 V or less on receiver it will output 960. (there is no way to turn this off on the turnigy mini failsafe)
THEN!!! I did my first flight with the new failsafe. Everything was normal until I flew pretty fast and stopped quickly. my hex shot up then back down into the ground, then flipped. Nothing is physically broke but I havnt flown sense.
A few thoughts. I think the receiver voltage may have dropped bellow 4.2V when I stopped suddenly because I pulled a lot of current on the motors. Sense the mini failsafe sensed 4.2V or less it triggered RTL.
Question: when failsafe RTL is activated, how do I regain control? Do i have to switch to another mode then back to stabilize?
According to the logs, chanel 3 only outputted 960 for a second or two then it went back to 1040 or so but the hex remained in RTL and never went back into stabilize.
I thought once signal was regained I would be able to regain control??
I am not good at reading the logs and I am trying to figure out exactly what happened.
The crash is at the very end (obviously) but the beginning is me setting up and calibrating new failsafe. I should have disconnected and reconnected before my flight to avoid such a long log.
the sensor health and a few other things seem to happen at the same time as RTL but I am not sure what all the values mean.
