Hello ,
i have t-motor M501 300kv motors which in their specs write max 5000 rpm.
In the RCOU i see max value of 1600, is there a way i can make that number correspond to the specific motor min-max rpm ?
Can i see from the logs the presentence of the motor throttle? e.g. was the 1600rpm with full throttle ?
from the GPS.speed i see max speed 6m/s , is that the way to see the ground speed?
Are there any settings to tweak to make the copter faster? the only parameters i see for setting speed is for WayPoints
Thank you for your time,
Best!
