If it is of any use, this is what I get when running “vagrant up” now
toniv@LAPTOP-TU55PHQ7 MINGW64 /c/Code/Master/ardupilot/Tools/vagrant (master)
$ vagrant up
Bringing machine 'bionic64' up with 'virtualbox' provider...
==> bionic64: Checking if box 'ubuntu/bionic64' version '20220424.0.0' is up to date...
==> bionic64: Clearing any previously set forwarded ports...
==> bionic64: Clearing any previously set network interfaces...
==> bionic64: Preparing network interfaces based on configuration...
bionic64: Adapter 1: nat
==> bionic64: Forwarding ports...
bionic64: 22 (guest) => 2222 (host) (adapter 1)
==> bionic64: Running 'pre-boot' VM customizations...
==> bionic64: Booting VM...
==> bionic64: Waiting for machine to boot. This may take a few minutes...
bionic64: SSH address: 127.0.0.1:2222
bionic64: SSH username: vagrant
bionic64: SSH auth method: private key
==> bionic64: Machine booted and ready!
==> bionic64: Checking for guest additions in VM...
bionic64: The guest additions on this VM do not match the installed version of
bionic64: VirtualBox! In most cases this is fine, but in rare cases it can
bionic64: prevent things such as shared folders from working properly. If you see
bionic64: shared folder errors, please make sure the guest additions within the
bionic64: virtual machine match the version of VirtualBox you have installed on
bionic64: your host and reload your VM.
bionic64:
bionic64: Guest Additions Version: 5.2.42
bionic64: VirtualBox Version: 6.1
==> bionic64: Mounting shared folders...
bionic64: /vagrant => C:/Code/Master/ardupilot
==> bionic64: Machine already provisioned. Run `vagrant provision` or use the `--provision`
==> bionic64: flag to force provisioning. Provisioners marked to run always will still run.
