I’m trying to save a planned mission’s waypoints as a Json .mission file. Every time I go to save I get a generic pop up box that just says “Error” with the click ok button.
I need to be able to save the mission as a json file so that it can be used with another GCS when flying a DJI drone in addition to one running a Cube orange.
The waypoints are for a polygon survey area and include spline outbound/inbound points with overshoot & lead-in set to 175m.
Is it a setting that’s causing the issue or something else?
Apparently (on MacOS MP) it works (no error indicated) if you put explicitly a .plan (or any) extension, but basically you get the same file, so I wonder if this is supported by MP.
So read the .waypoints file with QGC and save it as .plan.
Sorry it’s an error when saving it as a .mission file not a .plan one (edited initial post to reflect this). Unfortunately I can’t post a .mission file as it’s not letting me save one. I can upload a standard waypoints file if that helps.
