Hardware: 3DR ArduPilot Mega 2.5 (Fully Assembled)
Computer: Win8 x64
Connection: USB
Last week using Mission Planner 1.3.5 I was able to connect to APM, upload firmware, configure and fly (no crashes). Everything went fine until suddenly APM stopped responding today.
So I pulled it out of the quadcopter and have it connected to my PC via USB cable.
Using the latest daily (6/14/2014) of APM Planner v2.0.10 I get the following error when I try to install firmware: “Unable to gain access to bootloader”
Uploading firmware on Mission Planner 1.3.5.1 (latest) gives the “Communication Error - no connection” error.
Mavlink no longer connects… just hits the timeout with “No heatbeat packets received”
I’ve tried:
different USB ports
different USB cables
different serial ports (com3 was working last week)
different serial speeds (115200 was working last week)
I believe I’m seeing the same thing on two of my boards. If I try to use APM Planner 2.0 and show the output I have avrdude.exe: stk500_2_ReceiveMessage(): Timeout.
When I power on I get the Red/Blue flashing on the Output side that goes to solid yellow. On the input side I get the solid red for Alive. I’m in San Diego so if you’d like me to bring the two boards that are showing the problem by I can.
Here’s the console output from Mission planner when I try to do anything with the board…
INFO MissionPlanner.Utilities.adsb - adsb connect loop
PNPID: ACPI\PNP0501\1
PNPID: USB\VID_23C1&PID_B016\75331313033351D08061
PNPID: USB\VID_2341&PID_0010\64033333430351A071B1
INFO MissionPlanner.Arduino.BoardDetect - is a 2560-2
INFO MissionPlanner.Utilities.Firmware - Detected a b2560v2
INFO MissionPlanner.Utilities.Firmware - Using firmware.diydrones.com/Pla
ne/stable/apm2/ArduPlane.hex
INFO MissionPlanner.Utilities.Firmware - OK
INFO MissionPlanner.Utilities.Firmware - Downloaded
CustomMessageBox thread calling Base Thread
CustomMessageBox thread running Base Thread
