Unable to get heartbeat from mavproxy or pymavlink
Unable to get heartbeat from mavproxy or pymavlink, but when I am opening QGC, its getting all the info & I can arm or even takeoff.
I am using real copter & not using any SITL. I am using USB to connect & I changed the parameter CBRK_USB_CHK to 0.
That was working till last night. Now the same code is not working but in QGC everything is fine.
Any idea?
Thanks
Mavproxy
mavproxy.py --master=/dev/ttyACM0 --baudrate=115200
pymavlink
from pymavlink import mavutil
connection = mavutil.mavlink_connection("/dev/ttyACM0", baud=115200)
connection.wait_heartbeat()
print("Heartbeat from system {} component {}".format(
    connection.target_system, connection.target_component))
Not enough information… please refer to Download and Installation — MAVProxy documentation
you can also use dronkit
https://dronekit-python.readthedocs.io/en/latest/guide/quick_start.html
Thanks @Zerocool
Sorry for less information.
Could you please point it out what are the information do you need?
Looks like you’re using PX4, not ArduPilot: people might be more familiar using PX4 at discuss.px4.io so that might be a better place to seek assistance.
If you meant to be using ArduPilot, first thing to do would be to flash ArduPilot firmware and see if the problem persists.
Yes right.
You are correct.
Hi @Zerocool & @james_pattison
It resolved by restart the system & with the same code now its working.
