When I tried using the S.port on the XSR’s connector, it showed nothing but the receiver specific telemetry sensors (3 of them) as expected.
I went by this guide to get the uninverted signal from the receiver.
Afterwards the GPS sensor showed up with the value of zeroes. Which is fine since I don’t have a GPS antenna yet.
However, none of the other sensors were there. What else am I supposed to do? How do I test if the connections are correct?
Is there something else I need to set up in Mission planner?
There is a very high possibility that I just forgot something or screwed something up, tell me anything you can think of!
Give it a shot, drag and drop the yaapu files onto the tx16 sd card and add it as a widget. Make sure you have the correct serial port settings i.e. SerialX_Protocol set to 10.
It seems you were right! It’s working very nicely now.
Thing is, the sensors stop as soon as I stop the Yaapu script (i.e. I change the screen)
Meaning if I wanted some functionality like Vario, I would have to keep the script running.
But it’s good enough for now. I might deal with that later.
