Greetings for the day!
I have connected my seed spreader EPS200 to Pixhawk Cube orange+ aux2 out Servo Function 14. The seed spreader motor is not running in all 6 aux output, so I checked the frequency received by the aux out
Then I connected the seed spreader to main out where it was working while motor testing, I have Noted the frequency in this. Also, I have attached (Seed Spreader - Google Drive)both the frequency received from aux and main Outputs for the reference. , but I couldn’t configure the seed spreader to run it in aux out.
RC Minimum Response
RC Maximum Response
RC Minimum Response where Condition was a motor test with throttle 100%
RC Maximum Response where Condition was a motor test with throttle 100%
I have attached the video for the reference.
Any suggestions to make it work.[Aux and Main Out signal frequency]
