The compiler says, that nuttx/config.h is missing. I placed the ardupilot directory to cygwin/root and am working on a fresh clone of the repo. Of course I ran submodule update.
Frankly, I haven’t been able to build for days and am getting different error messages depending on the build-system and version of plane I’m trying to build…
When updating submules over cygwin, I occasionly get the error-message that ’ : is not a valid identifier’. I figured that this might have something to do with line-endigs and issued “git config --global core.autocrlf false” in cygwin. I also checked my windows installation of git, but autcrlf was set correctly.
I have redownloaded several times. Did clean compiles and re-installed toolchain. To no avail. This is beyond my comprehension.
EDIT: I tested wether it makes a difference if I clone the files with my windows version of git or the cygwin-version. It doesn’t. The error-message doesn’t change.
I found the reason for the ’ : is not a valid identifier’-error-message.
I copied export PATH=$PATH:/cygdrive/c/pixhawk_toolchain/toolchain/bin from build with waf using cygwin
Which introduced ill-formated charakteres. Tipping by hand made the ‘identifier’-errors vanish. But buidling still doesn’t work.
Could somebody upload a working cygdrive directory with a compilable arduplane-3.9.* folder? if that doesn’t work, I’m probably gonna migrate to a fresh linux machine…
Building sitl in vagrant works… So something concerning my cygwin setup or toolchain installatiion must be off.
EDIT: Of course I already checked if all cygwin packages are installed and reinstalled px4-toolchain, including deleting toolchain and px4/workspace directories.
