QGCExternalLibs.pri:381: error: Extra characters after test expression.
(ParameterCheck)
and error: Unknown module(s) in QT: declarative webkit phonon svg
The linux instructions should be corrected to contain this:
go to libs/thirdParty -> libxbee
sudo su
Create Library -> Readme file in folder
exit
Ubuntu Application Menu -> Development -> Qt Creator
common sudo is not enough to do a make install for that library.
no, I posted just to confim what version I think at had at job, will be back there within 10hrs, and can try again in case source changed in a way that helps.
Will confirm the version then…
The Qt Creator 2.7.1 for 64bit Ubuntu is based on QT5.0.2
So it comes with both qmake-qt4 and qmake-qt5
I tried to force it to use qt4 by compiling in terminal:
qmake-qt4 qgroundcontrol.pro
make
But then, after compiling well for a while, it fails with
In file included from src/ui/XbeeConfigurationWindow.cpp:3:0:
src/ui/XbeeConfigurationWindow.h:10:28: fatal error: QtGui\qcombobox.h: No such file or directory
#include<QtGui\qcombobox.h>
compilation terminated.
make: *** [build-release/obj/XbeeConfigurationWindow.o] Error 1
thanks - after counting 9461 issues, if failed with
apm_planner/src/ui/configuration/PX4FirmwareUploader.cc:4: error: openssl/rsa.h: No such file or directory
Anyway, thanks for trying, I will wait till you can look at it
[quote=“Andre-K”]thanks - after counting 9461 issues, if failed with
Anyway, thanks for trying, I will wait till you can look at it [/quote]
Looks like you’re missing libssl-dev. I’ve also pushed a change to master branch to remove Linux build from XBee until we can fix XBee library building in linux. Re-checkout master, run that apt-get line, and it should build for you.
Can anyone point me to the build documentation to install on Ubuntu 32bit, or is there a .deb package available ?
I’ve tried searching and end up going round in circles and need a step by step guide to follow as a Linux noob.
