I have set the TXMOD network to station mode and successfully connected to the local network. I can see his webpage on the ip assigned. I cannot get the Mission planner connected to UDP port 14550. Any help appreciated.
Screenshot: https://www.dropbox.com/s/419ceylhf8vdurb/Screenshot%202020-02-18%2007.40.37.png?dl=0
whats at the other end of the link? There needs to be something talking mavlink for it to connect.
On the other side is an rfd868x bind and connected to a quad as usual. I was connecting to the TXmod with TCp/ip as hotspot before.
Ah station mode, you might have to setup some port forwarding on the router its connecting to
Ok I see thanks i will try that. Any idea which port to 14550? 23 Maybe?
