[1] Two Tilt Servo’s PWM Range : 1050~2000(Two servo pwm range was same)
[2] Two Tilt Servo’s action in Manual mode : The motor become straight well
[3] Two Tilt Servo’s action in QStabilize mode : One of the motor does not reach to upright straight, as per the video.
only one motor reach to upright straight angle.
[4] Result :
Servo pwm value range was same(1050~2000) but the two servo’s tilt degree was different.
so I adjust “TiltMotorFrontLeft” to 1000~2000 and the problem was solved.
PWM range is different, but actual tilt servo degree is same.
I’ve setup a couple of VTOLs and most of the time they will not have identical PWM range. I just adjust the endpoints independently to reach back enough so prop doesn’t strike wing in vtol mode, and straight forward in FW mode. Then adjust the Q_TILT_YAW_ANGLE so it’s perfectly vertical in VTOL mode. This is the documentation I followed: QuadPlane Setup Tips — Plane documentation in the “Tilt Rotor Setup” section.
Yes, the PWM range can be different due to the tolerances of all components. Most normal servos have not a high grade processor unit with an low tolerance xtal but simple RC timer.
