GRS26
(GRS26)
September 29, 2021, 3:05pm
1
I tried looking in the wiki, but couldn’t find my answer. I want to use two digital, I2C air speed sensor using arducopter, but I don’t if it’s support, not the configuration steps necessary if its supported
dkemxr
(Dave)
September 29, 2021, 3:30pm
2
Arducopter doesn’t support Airpseed sensors to my knowledge. Plane and Rover.
hendjosh
(Josh Henderson)
September 29, 2021, 4:43pm
3
Here is an old PR to add that in. But it would need some work to update and test it.
ArduPilot:master
← chobitsfan:pr_airspeed
opened 09:45AM - 18 May 18 UTC
fix #7654
Airspeed sensor can provide more data about copter flight status. … It is important for remote operation or flight beyond line of sight. I need airspeed reading for my current project. So I do it. Thanks @rmackay9 's advices. Tested on my quadcopter (analog airspeed sensor connected to pixhawk ADC 6.6v)
Hi @bnsgeyer , Would you be able to taking a look? Because you mention that you have done it before. Thank you very much.
hendjosh
(Josh Henderson)
October 21, 2021, 3:55pm
4
Just as a note I have PR here to add this that is 85% along the way to being good to go.
ArduPilot:master
← hendjoshsr71:pr/heli_airspeed
opened 08:57AM - 01 Oct 21 UTC
To be added after PR https://github.com/ArduPilot/ardupilot/pull/18838 which mov… es AP_Airspeed usage up into AP_Vehicle
@bnsgeyer
This adds airspeed support to copter and replaces https://github.com/ArduPilot/ardupilot/pull/8430 & Closes https://github.com/ArduPilot/ardupilot/issues/7654
I tried to incorporate most of the comments in the above PR. It does not incorporate any control elements or autocal. This is reporting only.
**Notes**: This PR adds 13.6 KB to copter it is defined out for boards 1MB or lower
**Questions not addressed** in above PR: What happens in the EKF if someone tries to use airspeed?
I tried to make the default ARSPD_TYPE in SITL with Copter to be NONE, but that led to issues with the autotests not holding the param through the restart....???
**Tested in SITL only:**
Type == Analog
Type == MS5525 Weird Data here between mode types
hendjosh
(Josh Henderson)
January 19, 2022, 7:39am
5
Three months later and a lot of things in between and this is in master now
bnsgeyer
(Bill Geyer)
January 19, 2022, 10:38am
6
Thank you @hendjosh for your hard work on this. Much appreciated!!
