I’m trying to use serial5 connector for rangefinder LW20 without succes
can you help me?
I tryed the same setup on serial2 and it work perfectly.
So Maybe we can’t use it for range finder?
can you help me?
Try swapping RX/TX if you haven’t already. You can use an LW20 on any serial port.
If you have the carrier board with ADSB receiver then it is hardwired to Serial5
