Hallo, I have troubles with my quad. It is about Loiter and RTL.
Sometimes everything works OK - switching to loiter mean quad is stable in position; switching to RTL mean quad take correct height (by settings), change orientation (by settings - I use changing front to the home), then quad fly above place of landing and starts landing.
But!
Sometimes it doesn´t works. Switching to RTL, quad start to fly above place of landing but starts to make spirals falling down, and I´m affraid continuing in spiral will finish at crash. Sometimes spirals starts imediately after switching to RTL. Sometimes quad changes orientation (front to the place of landing), sometimes not. And every this situation can be during one fly!
Similar problem is with Loiter, sometimes is OK, sometimes starts fly at spirals.
[quote=“pad73”]Hallo, I have troubles with my quad. It is about Loiter and RTL.
But!
I made compassmot procedure with result 183% … I changed wire instalation and I have 20% now. So tomorrow I will test it. We will see if it was source of troubles.
