I built a Tricopter VTOL UAV with AUW 10.5Kg. Each motor at 50% can give approximately 4.5kg of thrust consuming 20A. But when the drone hovers it takes in 90A and a voltage drop of 2V. The power module is calibrated and the plane is tuned. Not able to figure out why the excess power consumption. Any suggestions.
Front two motors are T motor AT5220 380KV with 19x10 props and back motor is T motor MN605S 320KV with 22x6 props. It is a 6S system. Firmware is the latest stable version. Could vectored yaw be the reason?
