Hello
Can I in a simple way track my airplane in MP?
I need a PC software to track independly my aircraft , using gnss antenna mounted on the fusealge.
PC is inside the plane and it’s operated by crew member. Antenna can be connnected directly to the PC - by some hardware I belive, because it has sma connector.
Autopilot in my aircraft can import GPX file as a route - does MP export route in GPX?
I want to use MP as a control software for photogrammetry missions - I don’t know if it can control the camera’s trigger….
Lots of stuff…
Regards
Greg
