Hello Guys,
I am totally new to Ardupilot framework. I am interested in Ardupilot for drone purpose.
So my question is very simple: Where should I start?
I believe that copter is the most adapted framework.
I have another question: what is the most adapted drone for Adrupilot on the market; which is simple and easy (If there’s any?)
If this question is offtopic, you may move this post to a more appropriate forum
Thank you
I think you should start building simple drones first because there are millions of people have built a drone. And I don’t recommend buying any drones and working on it. So basically build a quad first
but it needs a flight controller and GPS, easy enough to get something.
You might be able to find a supply nearby, chances are it will be someone that sells the Cube flight controllers and other Cube gear.
That tends to be a more personal choice than the other hardware. I wouldn’t use a Transmitter that didn’t run OpenTx so that’s Frsky, Radiomaster or Jumper and one other oddball I forget the name of. I had a Frsky Radio for several years, good stuff. I have a Radiomaster now that I like. You will get many opinions.
