Hi there!
since the Toshiba LED used on pixhawk board, is end-of-life, can someone advice on a valid I2C alternative compatible with latest APM firmware release?
Thanks a lot!
a.
Got this one recently on amazon and it works:
If the plug doesn’t go in to the socket all the way, look at the sides of it. I had to shave the key on each side to half the length to fit into the Pixhawk i2c socket. Other than that, both the led and usb work perfectly.
Rick
Thanks
I also have one of those but it has the same Toshiba TCA62724FMG at end-of-life.
I am searching for an alternative component already implemented into the firmware, because I need to design my own board
cheers
a.
i have implemanted a bridge to ws2801 leds with an arduino
do you have found the alternative for the TOSHIBA LED TCA62724FMG? because currently I’m designing my own board too and I see this component is no longer available. please do help.
cheers
