Topotek KHP290G609L11 - 1080P Daytime + 640*512 Thermal + 1100m Laser RangeFinder, only 255g! Ethernet and HDMI video output.
The 3-system gimbal camera integrates a 5-1100m laser rangefinder, a 1080P daytime EO CMOS sensor (FOV: 60°x43°), a 9.1mm lens 640*512 thermal sensor (FOV: 34.4°x25.8°) and a 3-aixs stabilizing gimbal, coming with built-in cars and humans tracking function.
@Ellie_Lee_Topotek so the answer is: It is not compatible with ArduPilot, Topotek has developed it’s own serial Protocol instead of using the Mavlink industry standard, and the custumers should create a device drever in C++ for Ardupilot if they want to use this Tropotek camera.
Our LUA will be available before January 1st, 2024. BTW, can I have your mail address, pls? Or you can write to my mail: lihui@topotek.com or you can add my whatsapp: +86 13858839347
1.Firstly, you can download the source code from https://github.com/laozhou-fujian/ardupilot.git, then configure the compilation environment, wait for the compilation to complete, and generate the new firmware.2. After installing the new firmware, run the ground station and set the following parameters:
Take the use of flight control TELEM 1 interface and Camera 1 control as an example: SERIAL1_PROTOCOL Set it to 8 (" Gimbal “) SERIAL1_BAUD Set the value to 115, which is 115200 baud rate MNT1_TYPE Set to “12” (”) and restart flight control MNT1_RC_RATE is set to 90 (deg/s) to control the gimbal speed when using the remote CAM1_TYPE is set to 4 (“Mount”) to allow camera control RC1_OPTION Set to 212 (" Mount Roll “) to control gimbal roll through channel 1 RC2_OPTION Set to 213 (” Mount Pitch “) to control gimbal pitch through 2 channels RC3_OPTION Set to 167 (” Camera Zoom “) to control the zoom through 3 channels RC4_OPTION is set to 214 (” Mount Yaw “) to control the gimbal yaw through 4 channels RC6_OPTION Set to 163 (” Mount Lock “) to switch between Lock and Follow mode through 6 channels RC7_OPTION Set to 166 (” Camera Record Video “) to start or stop gimbal recording through 7 channels RC8_OPTION Set to 9 (” Camera Trigger “) to take pictures of the gimbal through 8 channels RC9_OPTION Set to 175 (” Camera Lens “) to control ption-in-picture through 9 channels RC10_OPTION Set to 168 (” Camera Manual Focus “) to focus manually through 10 channels RC11_OPTION Set to 169 (” Camera Auto Focus “) to focus through channel 11 RC12_OPTION Set to 174 (” Camera Image Tracking ") to control the gimbal pair through 12 channels Image center point tracking (requires gimbal tracking function)
Please note: Due to the problem of partial flight control, it is recommended to restart the flight control system twice after the successful setting, otherwise some functions may fail.
Владимир Феднин via ArduPilot Discourse <noreply@ardupilot.org>于2024年3月11日 周一23:19写道:
Hi, we have this camera on sale from April 1-15, 2024 with the price set at US$2616, please don’t hesitate to contact me if you are interested, my mail lihui@topotek.com, whatsapp: +86 13858839347
