I have problem when desceding with quadcopter, quad wooble to much.
Specs:
NTM 1200kv
ESC 20A Simon K
2200mAh battery
APM 2.5 with NEO6m GPS
x666 frame from hobbyking
BEC for powering
Can somebody look at my log and give me some advice.
When descending too quickly the multi-rotor is encountering prop wash that is causing it to wobble. The prop wash is very turbulent and can cause the multi-rotor to destabilise. One solution to this is to slow your descent velocity, another is to physically change the angle of the propeller to send the downdraft away from the aircraft. Say 5 degree tilt off the horizontal.
