I’m pretty excited 4.5 beta supports Tmotor’s Datalink2. I can finally get telemetry from my Alpha esc’s! But it seems it’s recommended to autotune without the payload. Here’s my issue, but some specs first:
-1300mm X8 coax configuration
-Tmotor U8II motors with 28/9.2 props and Alpha 60aHV esc’s
-12s 30ah battery
-all up weight without payload 14.94kg
-all up weight with payload 17.97
I’d also like to use the copter without the payload for things like power line pulls. So You’re basically starting at 14.94kg. If it’s tuned at almost 18kg, the rates will be too high without the payload. So tuning without the payload seems like a good idea. But the motors are generating (according to Tmotor) 3.23kg of thrust at 50%. At the 15kg range, I’d still only be around 38% for hover and that’s throwing in a 25% loss on the lower motors. Normally overpowering isn’t that big of a deal, but larger props may make it difficult to find a spin min that’s still turning lol. Any thoughts before I spark this up?
