I’m working on a tilt wing tricopter with non-vectored yaw, tilting the rear motor. I have set the q_frame_class to 7 for tricopter and servo9 = 39. I assume that in Q_stabilize I would have yaw servo movement on the rudder stick. Is this correct? Also I notice that Q_M_YAW_SV_ANGLE isn’t even listed.
I see it in the documentation however I wasn’t able to find it in the firmware. After a couple of reboots I now see it. Thank you.
hi shawn,
i am having a issue as my Yaw Servo with function 39 does not seem to respond.
although it centers the moment i press the Safety switch but that’s it… no further inputs are visible form the Rudder stick on that servo.
As I recall the FC needs to be armed and you need to apply throttle before it will move. I would check but my build is in pieces all around my shop right now.
thank you for the reply Shawn,
will try that as suggested! but this is really taking me to a mentally breaking point as the Yaw servo of the rear motor just refuses to budge no matter what…
