Hello. Please refer to below Information, Flight Video, Flight log, time table :
(1) Aircraft Model : Freeman 2100 VTOL(MakeFlyEasy)
(2) What I have done with this aircraft:
Built VTOL and tested with Quadcopter mode, set up parameters as maker suggested, extended airspeed sensor for preventing airflow on tilt prop to affect airspeed sensor(It worked), Checked fixed wing servo neutral position and direction(Including tilting aircraft on QStabilize mode and watch it react to tilting), Checked Weight balance, battery is tightly installed inside frame
(3) Problem : as described on the Post’s title.
It suddenly started to dive into the sea/ground whenever I fly it and I changed to QHover mode and manage to land safely everytime it dives.
(4) Video and flight log :
(5) Time Table of video :
02:56 Changed mode from QHover to FBWB
03:10 Sudden Decrease about 13m, at airspeed 19m/s, changed to QHover
03:11 GPS speed increased to 30m/s, meaning that it almost dived into sea
04:11 Changed mode from QHover to FBWB
04:20 Sudden Decrease about 10m, at airspeed 20m/s, changed to QHover
04:22 Airspeed increased to 31m/s, meaning that it almost dived into ground
05:12 landed with QStabilize mode
It seems that the aircraft is okay until GPS speed 19m/s, and after the speed it dives.
before, airspeed sensor was not good and that time it dived with airspeed 12m/s and GPS speed 19m/s
I’m not very sure, but I put my transmitter at neutral.(didn’t touch the throttle)
