Dear Friends,
Today I try to Autotune my big Copter. (Octo, 18inch Props, 4.0.0_dev)
Everything went well until suddenly I got the Message ERROR, THRUST LOST and he was descending, He didnt fall out of the Sky.
First I thought it was a Battery Issue cause its pretty cold at the Moment. Then I took a new preheated pair bút same Problem.
First all was good and suddenly the same Situation appears again.
Before a lot of people are starting to think. I think i know what It is about.
Tomorrow i take my other Copter . IT is build nearly the same except ECSs / Engines
For me it looks like an ESC / Motor Problem
today I flow my other Octo. As i told before, everything same except Engine / ESC.
Absolutly perfekt. No Problems at all.
So its def. an Engine / Esc Problem. The funny thing is, that he flys absolutly perfekt and then suddenly, after more or less the same Time time he is descending with that Error Message like a thermal heat Problem
The ESC ist the OctoBLC from MK, which is normally a wonderful ESC and the Engines are from KDE Direct 340KV. Both are normally very good and reliable Products but together they are unfortunately not working.
Sad…
