I can limit throttle using the max parameter, this limits throttle in both manual and auto mode, how do I make sure that the limit is only in auto mode?
dont know of any way…why do you need this?
We used to have a tkoff_thr_max, but changed that to a time to apply thr_max before changing to TECs
I need this so that the aircraft does not consume too much energy in auto mode
I’m sorry, I meant FBWA
actually, you were almost correct, and my memory was a bit faulty…
- THR_MAX is Maximum throttle percentage used in all modes except manual, provided THR_PASS_STAB is not set.
- TKOFF_THR_MAX limits The maximum throttle setting during automatic takeoff. If this is zero then THR_MAX is used for takeoff as well.
3.if THR_PASS_STAB is set then then when in STABILIZE, FBWA or ACRO modes the throttle is a direct passthru from the transmitter. This means the THR_MIN and THR_MAX settings are not used in these modes.
as to limiting power consumption in AUTO modes:
- set the cruise speed using AIRSPEED_CRUISE(if you have an airspeed sensor) or TRIM_THROTTLE if you dont (be sure you have trimmed the plane for this cruise throttle, read Tuning Cruise Configuration — Plane documentation) to the lowest safe point for flight while in cruise mode…
- Plan the mission in AUTO such that rapid climb demands between waypoints are minimized.
- Be sure you have the TEC tuned well see TECS (Total Energy Control System) for Speed and Height Tuning Guide — Plane documentation
Thank you very much)
