I have massive throttle pulsing in cruise mode near the start of the flight. Can anyone help determine the cause of that?
Also, the radio tx has some glitching (a few us) but even in manual mode the throttle out is glitching far worse than the Tx in. Is there something I can do to fix that?
The google drive is locked. I can’t access the file.
But I"m not sure it will tell me much. If the RC in is moving like that it’s probably a physical issue, not a setup. If you’re using an OpenTX radio make sure your stick calibration is good. Verify your wiring is clean and there’s no distortion. Maybe you’ve got the dead-band on the throttle channel too small and it could be tweaked up a couple of points.
