Hi guys.
My problem that I have is on the throttle and does not respond linear with the stick movement. The quad does arm and disarm but the throttle just stay at one speed and sometimes jumps up and down but does not react with the throttle movement on the stick. I’ve set the parameters on the throttle settings but still don’t make much of a difference. The calibration was done also and was in stabilize mode all the time for starters.
I’m using the HK blue series 30Amp ESC and the AX 2810 750kv motors with the HKmega pilot 2.7 and use MP 1.3.31
Any ideas what it could be.
