Hi All,
I anticipate that one of you fine folks will be able to point me in the right direction!
I’ve built a lovely new drone …
Problem:
- Motors only spin up to approximately 15-20% of max
- Any movement of the throttle above 20% seems to have no effect
Other information:
- Setup is an F550 Hex, Pixhawk with 3.1, T-Motor S25A 600Hz Opto ESCs, MN3508 380KV motors, 15x5 props, Aerialmob arms
- Radio calibration looks OK. signal moves from 993 up to 1997
- Motors seem to respond correctly across the full range of throttle inputs when in ESC calibration mode
I think that I managed to enabled motor logging and I have a log attached. I’ve been on the Naza train, and am new to APM/Pixhawk
Thanks heaps for any tips as to what I should look at!
