Hi Dev Team,
Thank you for the Awesome firmware that you produce. Great job!!
I have one broken board on input pin/channel no.3, is there any chance to map the THR input to another input pin?
Thanks in advance for your support.
waladi
Hi Dev Team,
waladi
[quote=“waladi”]Hi Dev Team,
waladi[/quote]
I had a problem like that when i got a board from china. Turns out the surface mount resistor was not fully solder to the board. Follow the input from channel three to the small surface mount resistor. Use a small wire to bypass the resistor. Go from the large input connector on the board to the inside edge of the surface mount resistor. Have someone help you do the check with you. They can move the throttle to see if the input changes on the mission planner. I have a solder work station and i was able to fix the input on 2 of my inputs. Cheap Chinese board. But it works great now.
Where was that board from? RCTimer? Whitespy? HobbyKing?
Mine was from Ebay
