Mini helicopters can be debugged and installed indoors…
Based on the current foundation, the optical flow sensor and Lidar rangefinder module have been further added. After a period of complicated debugging and experimentation, the traditional helicopter was finally successfully implemented in the indoor Loiter by optical flow positioning for the first time, cheers !!!
During set up…I’m trying to picture how you made rotor blade pitch angle measurements with a pitch gauge on such small, bendy (flexible) blades & blade mounts. Generally, toy helis have a good amount of swash plate slop too. How did you manage to get such impressive stability? Please tell us all.
Bravo to you on this great work. You are inspiring me to challenge myself more.
I do refer to the steps in the heli wiki for patient debugging, and combine my years of experience in debugging and flying mechanical and electronic equipment of traditional helicopters.
For the blade pitch angle setting of ultra-small helicopters, there is a more convenient method, such as folding the two main blades in the same direction by 90 degrees, and then measuring the pitch is very effective.
Sir Zhangpeng - could you take a photo or video of exactly how you position and use the pitch gauge with both blades folded back? When I measure small helicopters, the blades are too small to support a pitch gauge and I get wildly varying readings. Thank you. Mike
Sir Zhang - such ingenuity and creativity for making Pitch measurements on these small aircraft. I would never have thought of such a practical method on my own. I’ll try the same technique on a 450 size aircraft and compare it with a traditional RC Logger. Thanks for sharing your techniques and knowledge with us.
@zhangsir Got it, I tried the same setup as you with Copter 4.0.0 and I don’t see values. Also, tried the same setup on Kakute F7 AIO, same issue. Any ideas what might be wrong?
Good day. You mentioned that you had the same setup.
Where you able to complete your micro helicopter?
I was hoping that maybe you can share pictures of your wirings?
Can you post a screenshot of your heli setup?
Just wanted to compare my setup with yours.
I also used a Kakute F7 Mini but cant make the motor spin even if the heli is ARMED. I am thinking that I have the wrong setup. I connected my Servo 1 to M1; Servo 2 to M2; Servo 3 to M3; Tail Motor to M4; and Motor to M5.
The servos and tail motor work but the main motor does not.
Hoping for a response.
