I have finished hardware build, drone is up, 2 GPS and TFMini unit. All works fine, lidar provides data as needed.
Now, I believe in order for it to work one needs to activate EK3_ALT_SOURCE parameter?
Its definition states as below:
This parameter controls the primary height sensor used by the EKF. If the selected option cannot be used, it will default to Baro as the primary height source. Setting 0 will use the baro altitude at all times. Setting 1 uses the range finder and is only available in combination with optical flow navigation (EK3_GPS_TYPE = 3). Setting 2 uses GPS. Setting 3 uses the range beacon data. NOTE - the EK3_RNG_USE_HGT parameter can be used to switch to range-finder when close to the ground.
So, if you set EK3_GPS_TYPE =3 - that in fact turns off all GPS support. I do not want that. I want this unit to use lidar altitude when it is within provided range - indoors or outdoors. when out - use GPS or baro, as usual.
The WIKI page simply states like it is supposed to work ‘as is’ - http://ardupilot.org/copter/docs/common-rangefinder-landingpage.html
"Downward facing Lidar are used in flight modes which have height control, such as Altitude Hold, Loiter and PosHold Mode. The data from the sensor will be used until you exceed RNGFND_MAX_CM, after that it switches to the barometer."
So, that last statement sounds like complete common sense - only i have a feel after all tests done today - it is a lie and nothing uses that lidar value with the defaule value of EK3_ALT_SOURCE=0.
So, to simplify this BS - is it doable to use object avoidance and lidar landing/loiter together with GPS active? IF yes, how exactly it should be set and what parameters should be used?
If you want to use rangefinder both indoor and outdoor you need to add opticalflow in order to run loiter in non gps.
This way , you can set the range finder as the primary height sensor (until maximum range and then the Baro or Gps if present are used).
Beware of the fact that the TFMINI works indoor up to 12 Meter but is limited to outdoor at approx 6 Meters so you should be carefull about the settings.
I have not experiment with switching from GPS to OpticalFlow, but I know that it can be done. The problem is when you switch back from OpticalFlow to GPS, there will be a switch from local to global localisation and this can cause all sorts of weird situation going from uncontroled movement to try to correct from localisation error to total loss of EKF … generally it is switching to land
I see, it is making perfect sense but not what wiki gives a perception of, with a statement that alt hold uses rangefinder. I will try to search more, not quite sure how to do this switch from radio controls, from optical to gps flow either. Realistically, we do not need optical flow here, all we need is just a loop to set altitude using rangefinder as primary, if it exists.
Just did some tests, so, with ekf1/2 combo load in prearm is showing %45-%47, freemem says 44208.
With ekf/1/2/3 combo load in prearm is at %64-%67 and freemem is 11407. So, question of the day is - is %67 load level acceptable or not? Go figure…
The switch from GPS to OpticalFlow is automatic within the EKF, just like with 2 GPS its a ‘‘blending’’ of signal and uses the ‘‘best’’ estimator for navigation and if it fails it rolls back to AHRS and ultimately initiate an Land.
If you require more details , I suggest you open a new issue related to this particular to get other people involved.
May be i should, i still hope to find some details about it.
A switch to the optical flow as i see it is not automatic by the way of what is presumed between the lines of descriptions on the EK2_ALT_SOURCE and EK2_GPS_TYPE parameters.
For the first one it says pretty definitively - “Setting 0 will use the baro altitude at all times”.
And indeed it is what i see as indoors baro goes crazy and hits basement`s ceiling. it does not even look at the lidar. Then they continue: “Setting 1 uses the range finder and is only available in combination with optical flow navigation (EK2_GPS_TYPE = 3).”
That, again, presumes that optical flow navigation is not dynamic. I will try next to set EKF2 into EK2_ALT_SOURCE=1 and EK2_GPS_TYPE = 3 and setting EK3_ALT_SOURCE=0 and EK3_GPS_TYPE = 0 but not sure it was supposed to be like that.
Next complication is the AHRS_EKF_TYPE parameter that has to point to the exact EKF model and i do not see any confirmation anywhere that it may ‘switch’ between EKFs or care if one EKF is on lidar for alt and other is on baro.
Donno, all this is as clear as mud and i have no time at all to open up code and read all this stuff that is in there to decipher what is it expected to happen in what undocumented combination of parameters… It is too bad wiki is not updated to actually say HOW to use all those features they listed in there. it simply presumes it is expected to work, and may be it is indeed true, i just cannot figure it out, yet.
I saw some threads asking about same thing and there were responses of the RTFM type pointing to other threads that have 0 usable information. Very odd.
