Dears i did some modification for my new quadcopter frame for vibration issue i get some results tested on two identical flights same pilot same speeds same manueovers even start with hover end with some differint shapes flights for boht need some vibration expert to look into trends for both here is some changes only one you pitch all vibration decrease but when came to stop same vibration level as old quad can someone help and confirm .?
You need to plot all three vibes into the same axis, instead of using three separate axis, one for each direction.
It makes it harder to see the differences.
