I didn’t find something about it in the internet.
Does someone know how serious is it? Can i fly with the warning or do i have to solve this problem.
These are just guesses, but worth trying.
Disable your 2nd compass and see if you get the error. Its offsets are barely acceptable.
If that doesn’t help, re-enable it.
I have had trouble with my 3rd compass on the pixracer, even when it had good offsets. So, try disabling your 3rd compass and see if you get the error.
Test: Brownout = GOOD - Test: Compass = GOOD - mag_field interference within limits (16.99%) Max mag field length (612.70) > recommended (550.00)
Test: Dupe Log Data = GOOD -
Test: Empty = GOOD -
Test: Event/Failsafe = GOOD -
Test: GPS = FAIL - Min satellites: 0, Max HDop: 99.99
Test: IMU Mismatch = GOOD - (Mismatch: 0.36, WARN: 0.75, FAIL: 1.50)
Test: Motor Balance = GOOD - Motor channel averages = [165, 149, 165, 150]
Average motor output = 157
Difference between min and max motor averages = 16
Test: Parameters = GOOD -
