Greetings,
I am using a TeraRanger Hub Evo with 4 sensors facing forward, backward, left and right. Normally I would use the ports with numbers 1, 3, 5, and 7 on the TeraRanger Hub. However, port number 5 seems that it is not functioning as it should since it rarely seems to be working. I decided to rotate the Hub 45deg and use ports 2, 4, 6, and 8.
The proximity sensor plugin right now thinks that I use the “angled” ports and shows obstacles at the four quarters. Instead, I want to rotate the interpretation of the proximity sensor and use port no 2. as a forward sensor and not an angled one.
I tried using the PRX_YAW_CORR parameter by setting it to +45 and -45. It doesn’t seem to work. The proximity sensor shows exactly the same. I tried +180 just to see if something changes, but nothing happened.
Has anyone of you any idea on how to set this up correctly?
