Hi. I’m experiencing troubles interpreting a bin log file obtained through the temperature calibration procedure outlined in your documentation.
I’ve proceeded to a -10 to +70°C calibration from the freezer to the oven and I get the following 2 charts, one for the Accelerometer, the other for the Gyroscope.
The gyro one is absolutely scrap and I don’t understand why this. Would anyone have an idea that would help me sort this problem out?
It did the calibration in 90 seconds. Just to be easier on the board you could try to slow that down to maybe 20 minutes or more if you’re going to go from -10 to +70c.
Thanks for your suggestion Allister. It really makes sense. How did I miss this?
Reloaded the board in my freezer, and restarted the whole temp calibration procedure from -10 to +70°C. The calibration curves seem much better now (at least the corrections).
One point still I can’t understand: my freezer goes around -14°C, and I took care measuring my board temp once freezed. It was around -10°C. Whatever I do, Ardupilot reports a calibration starting at around +10°C (whereas it should be -10°C. Once in the forced flow oven, it completes correctly the cal procedure at 70°C.
What do you think of these curves? Acceptable? Any clue concerning the incorrect +10°C start monitoring?
