I changed the # channels from 10 to 50 and after copying to remote and then clicking save the two radios do not talk to each other.
OK an hour later and still not Luck. I tried clicking on default settings but that also didn’t work. I see that when clicking on the save button the green light on the pc radio will remain solid for a second and then start blinking again as soon as it says done after connecting. When clicking on the Load settings button the red light on the ground unit will flash a couple of times while connecting but will stop blinking once it says done at the bottom of the screen.
The red light on the Air Unit fires away but nothing happens on the ground unit.
Mine did that as well, so now I leave the channel numbers as set.
IIRC I just connected it the my trusty FTDI programmer and set it back to default that way.
