I have been tinkering around to change my telemetry from the standard 915Mhz over to wifi.
Solution at the moment is, to use a companion computer running mavproxy and send that via wifi to my ground control station.
But I just stumbled up on this topic Sending Pixhawk 2.1 TELEM1 data via RJ45 cable where the topic owner wanted to try an UART to RJ45 ethernet adapter. ( like this one https://www.iot-store.com.au/products/serial-uart-ttl-to-ethernet-module-usr-tcp232-t2)
Since I’m already using a router on my boat, this would be a pretty neat option to transfer the mavlink telemetry.
Problem is: the topic is closed. Hence why I’m asking here in a new topic:
Did anyone gather some experience with this? Does someone know If this would allow for an easy connection via IP address. Or would one still need to run mavproxy or something similar of any sort?
Cheers
