However, it has now stopped working. The green light keeps on blinking
Maybe I have upgraded the ground module from Sik radio by mistake. But I am not able to upgrade the air module as it does not support a micro usb connection like a Sik Telemetry radios.
I am still facing some issues with it.
In the Ground module - it is rfd Sik 2.0 on hm_trp whereas it is rfd sik 1.9 hm_trp in the air module. After correcting other parameter settings, I tried to connect both the modules. Both are now showing solid green led. However, they are not connecting through mission planner.
If it is necessary to have the same firmware on both the modules, please share the link for downloading the firmware.
(I have tried multiple baud rates too.) Check image for Ground and air module.
Hi I am having the same issue that you were. I ordered the FTDI module and it should arrive tomorrow. Were there any particular steps that you took to make sure it was updated or on the same firmware?
Hi I am having the same issue too.I have the same settings and firmware on both module.But they are not linking to each other.I am using sik radio telemetry v2.can someone please help?
Hello @ppoirier ,
I think even I am facing exactly the same issue.(I might have accidentally updated the ground module and not the air module.
I was able to connect once with my telemetry , then I took a screenshot.
based on my understanding of the discussion, because both my units(ground and air) have 2 different versions , I am unable to connect. So I downloaded SiK 1.9 on HM-TRP and installed it in the ground module using upload firmware option , and now I get this
also @ppoirier or @Harish_Patel could someone please tell me how
the flashing was done , I have Arduino UNO , I might be able to get myself NodeMCU or raspberry pi too ,if needed.
Also I don’t have a FTDI-to-USB cable mentioned in the wiki , is there any other alternative to it (like using Arduino, NodeMCU or raspberry pi or something else) that would be very much helpful.
