I’m trying to make my TBS nano RX working with arducopter 4.0.5
i’m with Flight Controller MATEK F405-SE, firmware 4.0.5 for F405-Wing.
TBS Nano RX, is wired on TX1/RX1. Its working good in Betaflight and Inav, and i didn’t change any wiring.
On the parameter, i have change Serial1_protocol = 23 (RC IN ) or 29 (Crossfire), both with differents bauds rate (57,115). None are working, the receiver is never detected on the Receiver tab of mission planner.
To be sure, i have disabled or put 1 to all other serial protocol, and still same result.
Any idea about what i’m missing? Any other parameter to setup?
Thank you for your help.
I have install the latest version, and made few tests:
with Crossfire (29) selected it doesn’t work
with RCIN (23) it works!! the crossfire is recognized, and i can see the controller in the tab.
BUT, their is a delay beetween what i do in controller and the result in screen, and also “fast” mouvement are not shown in the tab. Its like the system is too “slow” to detect all command.
i can make a quick video if needed and other tests
