Gerry_FPV
(Gerry FPV)
1
Hello everybody !
I can’t get the CRSF signal coming from the Nano Diversity to recognize on the Goku F745 AIO.
I flashed Goku F745 AIO with the last firmware
I wiring CH1 <=> RX UART3 and CH2 <=> UART3
I bind TANGO 2 and Nano Rx diversity and set up CH1=CRSF TX, CH2=CRSF RX
I change parameter
SERIAL3_PROTOCOL = 23
RSSI_TYPE = 3
RC_OPTIONS = 32+256 = 288
RC_PROTOCOLS = 9
Test with value 1 and 9
The next step is to set SBUS with CH3 to trybut I must change soldering.
It will be great If CRSF work with no SBUS…
Can you help me ? I don’t know what do…
andyp1per
(Andyp1per)
2
It’s bit 9 which means you need to set it to 512
Gerry_FPV
(Gerry FPV)
3
Hello ! Why 512 ? I did’nt see this value in RC_PROTOCOLS list
andyp1per
(Andyp1per)
6
There is a known problem with the nano diversity that is fixed in fw 6.10 - it’s probably worth upgrading just to make sure.
Gerry_FPV
(Gerry FPV)
7
I have 5 drones and many people Bricked there Tango 2 during update.
I tried before with the last version of Betaflight and CRSF work great with Nano diversity.
There is an issue With Arducopter 4.1 on this FC
If nobody have a new Idea, I will waiting and flying with Betaflight
Gerry_FPV
(Gerry FPV)
8
I try now with last version of Inav and it work too
If somebody see who I missed
