Have anyone been using these for longer periods of time?
I’m interested in the reliability of them and the performance of the crafts using them
Any input is appreciated!
With time they wear out. You need to replace the center pin with a more sturdy one.
Do you have any experiance of your own?
There is a v4 variant out there
it uses a flat larger pice to hold the arm up, and 2 springs. Would this variant be better.
Also, do you have any tips on what I should use to replace the pin with?
I would recommend this one instead.
