Install necessary tools:
sudo apt-get update
sudo apt-get install git python3 python3-pip
pip3 install empy
sudo apt install git
sudo apt install python3-pip
sudo apt install cmake
sudo apt install libgstreamer1.0-dev
sudo apt install libgstreamer-plugins-base1.0-dev
sudo apt install python3-wxgtk4.0
sudo apt install python3-matplotlib
sudo apt install python3-opencv
sudo apt install python3-yaml
sudo apt install libgeographic-dev
sudo apt install libtinyxml2-dev
sudo apt install libeigen3-dev
sudo apt install libxml2-dev
sudo apt install libsqlite3-dev
sudo apt install libboost-all-dev
sudo apt install gcovr
sudo apt install lcov
pip3 install --user future
pip3 install --user lxml
pip3 install --user pymavlink
pip3 install --user mavproxy
Clone the ArduPilot repository to your local machine:
- git clone GitHub - ArduPilot/ardupilot: ArduPlane, ArduCopter, ArduRover, ArduSub source
- cd ardupilot
- git submodule update --init –recursive
Install some required packages
- Tools/environment_install/install-prereqs-ubuntu.sh -y
- . ~/.profile
LOCK PARAMETERS IN THE CUBE ORANGE
Add the @READONLY flag to the parameters you want to lock in VS Code.
For example:
PARAM_DEFINE_FLOAT(PARAM_NAME, default_value, @READONLY);
Or
Set parameter lock password In the MAVProxy console, type:
param set LOCK_PARAM 1
param set LOCK_PASS your_secret_password
Replace “yoursecretpassword” with a strong password of your choice.
Lock specific parameters To lock a parameter (replace PARAM_NAME with the actual parameter name):
param lock PARAM_NAME
Save parameters
param save
Reboot the Cube Orange
Reboot
Flash the updated firmware that contains the locked parameters
Generate your public-private key pairs using the following command if private key already ready then skip the following steps
python3 -m pip install pymonocypher
Tools/scripts/signing/generate_keys.py NAME
this will generate pair of security keys, public and private
Tools/scripts/build_bootloaders.py CubeOrange --signing-key=NAME_public_key.dat
./waf configure --board CubeOrange --signed-fw
./waf copter
./Tools/scripts/signing/make_secure_fw.py build/CubeOrange/bin/arducopter.apj NAME_private_key.dat
OR
./waf configure --board CubeOrange --signed-fw --private-key NAME_private_key.dat
Upload firmware to connected CubeOrange
./waf copter –upload
Use MAVProxy to flash the signed bootloader:
mavproxy.py --master=/dev/ttyUSB0 --baud=115200
In the MAVProxy console, enter:
flashbootloader
OR
firmware load <path_to_signed_bootloader>
After flashing, verify that the new secure bootloader is installed:
Check the bootloader version by entering:
status
Open the parameter definitions in the ArduPilot source code.
Connect to the Cube Orange and check the parameters:
param show PARAM_NAME
CAUTION
Follow these steps carefully; incorrect procedures can render the autopilot inoperative.
Attempt to modify the locked parameters to ensure they are indeed read-only.
Always keep backups of your original firmware and bootloader.
