I have a catapult launched UAV with no throttle suppress before launch. Airspeed not used for throttle control (ARSPD_USE 0). After switching to AUTO mode with TAKEOFF command the throttle out is not set up to TKOFF_THR_MAX (100%) and in the data flash log I can see it outputs only 89% of the throttle. Before starting, it can reach 100% throttle with manual or FBWA. The log shows that TECS throttle out is at a lower value. I expected that if the throttle is not governed by airspeed then the throttle during takeoff has to be at TKOFF_THR_MAX level until we go higher than expected.
Why it may happen? What I can do to get 100% throttle at takeoff?
