I finally wanted to test TAKEOFF mode (without compass, by the way), but things didn’t go exactly as planned.
According to https://ardupilot.org/plane/docs/takeoff-mode.html, I was expecting the plane to fly in a straight line to a point located 200 meters from me, while climbing to 60 meters, following the heading I had thrown it.
Yet it went to the right soon after launch instead of keeping a straight line, then to the left after a while, as if it was already starting to enter the loiter circle, but it had reached neither the distance set nor the altitude at that point. It even paused the climb and descended for a while.
Combined with the fact that I had already thrown it too far right, the plane almost hit a treetop at 40m. Confused by all that and a new radio I’m not yet used to, I accidentally disarmed while switching to FBWA, flipping 2 switches at once. Luckily the plane was recovered intact - just in case you wonder when looking at the log. (Side note: Is there a way to safely enable re-arming in flight, without compromising prearm checks on the ground?)
Anyway, here are all the TKOFF parameters:
TKOFF_ACCEL_CNT,3
TKOFF_ALT,60
TKOFF_DIST,200
TKOFF_FLAP_PCNT,0
TKOFF_LVL_ALT,20
TKOFF_LVL_PITCH,20
TKOFF_PLIM_SEC,2
TKOFF_ROTATE_SPD,0
TKOFF_TDRAG_ELEV,0
TKOFF_TDRAG_SPD1,0
TKOFF_THR_DELAY,5
TKOFF_THR_MAX,95
TKOFF_THR_MINACC,5
TKOFF_THR_MINSPD,0
TKOFF_THR_SLEW,25
TKOFF_TIMEOUT,0
Log: https://we.tl/t-h8g7KExWKB
Thrust is definitely more than enough to make the desired climb (600mm ARWing Mini at 4S). I flew it and had it loiter many times at the same location with the same setup and no problems.
I used a triangle calculator to check the angle required to reach 60m in 200m distance - result is about 17°, so 20° should be acceptable? (Side note: I have to manually enter a new pitch angle value every time I change TKOFF_ALT and TKOFF_DIST, correct?)
I wonder if I should maybe enable the compass - but from what I read, TAKEOFF should also work without, and the lack of compass should not cause things like this?
Thanks for any hints!
