Tailsitter quad lost control after repeated ELRS RC short failsafes — ArduPilot + DB4 + TX16S + H743 Slim
Short summary
Hi everyone,
I’m looking for help analyzing a crash from 00000002.BIN.
Setup:
  • ArduPilot Quad X
  • Matek H743 Slim FC
  • DB4 ELRS receiver
  • RadioMaster TX16S
  • ELRS/CRSF
  • Nomad WiFi telemetry + Mission Planner
The flight initially hovered normally at ~9.2 m with ~30% throttle. At approximately 124 s, the log began showing repeated:
“Throttle failsafe on, RC Short Failsafe: switched to QLAND”
The failsafe cleared after roughly 0.3–0.4 s and returned to QLOITER, repeating about every 1.4 s.
At approximately 136.4 s, the aircraft suddenly became uncontrollable. M3 went to ~1949 PWM while M4 went to ~1150 PWM, followed by a rapid roll and crash.
I would like to understand whether the ELRS/CRSF short failsafes could have contributed to the loss of control, or whether the later motor-output pattern points to an independent motor/ESC/propulsion problem.
I’m particularly interested in:
  1. Correct interpretation of the M3/M4 output pattern for ArduPilot Quad X.
  2. Whether the repeated RC short failsafes indicate an ELRS/receiver/CRSF/UART problem.
  3. Any known ELRS DB4 / TX16S / CRSF / ArduPilot failsafe bugs or compatibility issues relevant to this setup.
  4. Whether Nomad/Mission Planner telemetry could have any interaction with the RC link.
  5. What additional log parameters or ground tests should be checked before flying again.
BIN log: 00000002.BIN is attached.
I’m especially interested in determining the first actual fault in the timeline, rather than assuming the crash was caused by either the motor or ELRS without evidence.
You generally can’t attached log files directly here. place it in cloud storage somewhere and post a link.
