This is a very stable flying twin-motor fixed-wing aircraft. It has a very traditional aerodynamic layout. Then I turned on the Tailsitter function in the flight control, allowing him to take off and land in a very small space (of course, it is not windproof)
Please watch the video
Nicely done. What airframe is this? Do you mind sharing the setup and pixhawk configuration?
In China, we call it the Great White Shark. I don’t know if there is such a model outside China. It is a very stable aircraft.
20220115-大白鲨垂起.param (22.4 KB)
Found this plane on Aliexpress https://www.aliexpress.com/item/32847258175.html
May I know what is your motor and prop combination? might want to try this plane as well. thank you
DF2307-1450kv
7 inch propeller
40A ESC
21700-4s1p
MATEK F405WING
In fact, I just used the power provided by the official. Not particularly improved.
