Tailsitter biplane+4 motor
Take a look at this post:
The tailsitter quad X configuration will support the frame geometry pictured here:
Note that the PR with the new frame type with torque-based yaw has not yet been merged to master though. The quad X copter tailsitter in master should work too though.
I guess the wiki needs updating to include a description of support for “copter tailsitters”.
The parameter which selects this frame type is:
http://ardupilot.org/plane/docs/parameters.html#q-tailsit-motmx-tailsiter-mask
For a quad Tailsitter you would set Q_FRAME_CLASS to 1, Q_FRAME_TYPE to 1 and Q_TAILSIT_MOTMX to 15 if you want all 4 motors running when in forward flight. If you wanted to shut down 2 of the motors in FW modes, you would set MOTMX to 3 or 12, depending on which pair you wanted active.
